Professional Security Installation Services
Commercial field installation, configuration and technical support for security companies, integrators and enterprise customers.
Field Installation Services
CCTV Camera Installation
Mounting, wiring and positioning of IP cameras.
Camera Replacement
Swap-out of failed or outdated camera hardware.
NVR Installation
Setup of network video recorders and storage.
Access-Control Installation
Readers, controllers and locking hardware.
Reader Installation
Card, fob and keypad reader mounting and wiring.
Controller Installation
Access-control panel and controller setup.
Door Hardware Integration
Strikes, maglocks and request-to-exit devices.
Cable Pulling
Structured cable runs for cameras and access-control devices.
CAT6 Cabling
Network cabling for PoE cameras and connected devices.
Low-Voltage Wiring
Wiring for locks, sensors and control hardware.
Camera Alignment
Field-of-view adjustment to confirm proper coverage.
Network Configuration
IP addressing, VLANs and device connectivity setup.
PoE Switch Installation
Power and data delivery for connected devices.
System Testing
Functional verification of every installed component.
Commissioning
Final configuration and sign-off before handover.
Troubleshooting
Diagnosis and resolution of system issues.
Equipment Replacement
Swap-out of faulty devices identified during service.
Maintenance
Scheduled or as-needed system upkeep.
Site Surveys
On-site evaluation before project deployment.
Multi-Site Deployments
Coordinated installation across multiple locations.
Professional Work-Order Execution
Every installation follows a consistent, documented workflow — whether it's a direct customer project or a subcontracted work order.
Clear project communication at every stage — from initial scope through to completion reporting.
Are you a security company or integrator that needs local field installation support?
Partner With SecXpertFrequently Asked Questions
SecXpert handles the full scope, including CAT6 cabling, low-voltage wiring, PoE switch installation and network configuration alongside camera and access-control hardware.
Yes. SecXpert performs field installation on a work-order basis for security companies, integrators and technology organizations. See our Partners page for details.
Yes, SecXpert provides installation completion documentation as part of the standard work order process.
